SpaceClaim: How do I parametrize an area?
I would like to parameterize a simple area, Height x Width with no thickness. Either the two sides should be parameter or the area as a whole.
So far, I tried creating the area pulling lines out of a single point. This gets me four lines that can be set as parameters. If if use 'fill' to create an area I still keep my parameters but the area doesn't change when I change the parameters. Only the lines themselves change. Could you help me out with this trivial problem?
Thank you!
