Difference between Dead and Solid regions Fluent Meshing
doing external flow with fluent , we supress geometry
so what is difference between making geometry region dead and solid ?
Best Answers
  • RobRob UKPosts: 9,687Forum Coordinator
    Accepted Answer
    It depends. If you don't want heat transfer through the solid part then dead is fine.
    Accepted Answer
    You would need to map surface data to Mech and re-calculate the temperature field. If you want a temperature field in the metal bit(s) use Solid.
    Accepted Answer
    Correct. Dead is void (effectively) where as solid is meshed and part of the model & solution.
    For info, "dead" was originally the designation for non-fluid cells when we had full cartesian meshes and needed to fit the geometry into a cuboid (last needed in Fluent 4). Those cells were included in the cell count, but didn't use much RAM. The term was retained for voids in Fluent Meshing.
