How do i find out resistance of coil in ansys maxwell transient 3d solver?
How do I find out internal resistance of coil in Ansys Mxwell transient 3d solver? I designed a generator and in excitation I added coil and external circuit . I want to know the inductance and resistance of coil. So that i can add same value of resistance as load resistance to get maximum power output based on Maximum power transfer theorem.
Also, in Motion setup when i give sinusoidal input velocity as 2*sin(2*pi*time) then output should be sinusoidal voltage and current. But I am not getting sinusoidal. Please help.
Best Answers
  • PoojaPooja Member
    When i give velocity as 2*sin(2*pi*time) I get this output. Why not sinusoidal ?
  • Thanks icellb1 and Navya !!
    Navya i am making linear generator to work in ocean thats why i am trying to give sinusoidal input velocity to the translator.
    Also, Can you please tell me is there any block of adding Sinudoial input in the external circuit so that i will get sinusoidal output. Like In MATLAB we have one sinusoidal input box which we can define and the values will come out as sinusoidal only. Is there any such way in ANSYS ?
    Thanks again Navya. You have always been so kind in replying.
  • Hi Navya.
    Can you please also tell how to define proper winding in ansys maxwell transient. The way I do Right now is, I define a section in coil and assign coil terminal to it. After assigning coil terminal I add winding and add this terminal to winding. Then I assign excitation as External and add external circuit. How would i know that the winding is done properly ,I mean whether its Distributed or not.
    Thanks heaps. You are solving my problems.
  • nchodenchode Forum Coordinator
    edited November 12
    @pooja,
    I am assuming you have permanent magnets on your slider.
    External circuit you are defining is on the armature with winding. So, I don't think you should add anything to this external circuit to get the sinusoidal induced voltage(output) as it may not reflect the practical case.
    As, a first check, can you assign a constant velocity to your slider and check if you are getting a constant and linear output voltage ?. Depending on this result you will understand how your slider moment is translating in to output voltage and whether it will really follow the velocity function. The reason I am asking you to do this is, as you know a linear generator is just a unrolled rotary generator and similar to rotary generator it should generate similar output voltage waveform depending on the construction.
    I don't have any details on how your model is and as an Ansys employee I cannot involve in your project work or home work or design directly except for tool support. I can suggest you the following.
    1. Do the above check with constant velocity.
    2. The way you are assigning the winding and excitation seems to be correct. You can also refer to the below Maxwell help documents for more information on setting up a transient simulation or defining winding.
  • Thanks Again for your quick response.
    I tried running with constant speed and I am getting sinusoidal output but I need to get sinusoidal output with sinusoidal velocity based on my project requirement.
    I can understand that you cannot help me beyond certain point but this is related to ANSYS only. I think there is some problem with the software as when you give sinusoidal velocity the output should come out as sinusoidal according to the literature. But in Ansys this is not happening. I am getting triangular shaped output. In my case the magnets and coil both are on the moving part.
    Also, regarding finding out the R and L of the winding coil in transient solution, I can use eddy current solver specifically to find out the R and L value and I can use the calculated values from eddy current solver into Transient Solver.
    Please clear my doubt regarding Ansys.
    Hopefully, i will find out the answers to my questions.
    Thanks Navya. You really helping me alot.
  • Thanks Navya for your response.
    I sorted this out.
    Thanks again.
