Tips and Tricks for determination of lift and drag coeffcient
            I have to know what kind of viscous model and other properties for getting appropriate values of lift and drag coefficient. Iam using 2d model. I am getting fluctuation of values each time when I use k-omega and k-epsilon models.
  • KremellaKremella Admin
    edited August 2018
    Hello Ananth,
    Thank you for creating a new post for your question. This might give you more visibility since your previous post was already marked 'answered'.
    As I mentioned in my previous post:
    • Would you elaborate a little on your mesh (especially the boundary layer mesh)? And which wall models did you use for k-eps and k-omega? Could you also elaborate a meshing strategy?
    • Can you please check the reference values for both the solutions and ensure they are the same?
    • Have you performed mesh independence studies?
    Best Regards,
