Extracting Related Equations from a Fluent Simulation
dileepatisseradileepatissera Member Posts: 7
edited November 2020 in Fluids
I did a Fluent simulation where i heated water flowing through a steel pipe. I wanted to see the temperature distribution on the pipe outer surface as a result of the fluid being heated from the middle. I aslo added turbulance models and radiation models as well. Now i need to extract the particular equations that was used by Fluent solver to perform the simulation to make a report on the simulation process.
Is there a way to extract all the equations (including the ones from the different models used) that was used to perform a particular simulation in Ansys Fluent.
