Using LS-RUN
I downloaded LS-PrePost and LS-RUN which was located in my ANSYS Inc folder. I was wondering if I can use LS-RUN to run LS-DYNA simulations with the Ansys Academic Research License.
I get this message when I try to configure my network license to LS-RUN:
"lstc_qrun.exe is needed to check license status.
Make sure lstc_qrun.exe is located in
the same directory as lsrun.exe.
lstc_qrun.exe is available from LSTC_LicenseManager
file from your LS-DYNA distributor".
Ricky
  • Hi Ricky,
    If you are able to run LS-DYNA with the Ansys Product Launcher or from the command line (using the Ansys Academic Research LS-DYNA license), you should be able to run it with LS-RUN.
    Just make sure you specify to use the Ansys License in LS-RUN. It looks like LS-RUN is looking for a legacy LSTC license (from the message you get).
    So, in LS-RUN, go to the License menu at the top and set "License type" to ANSYS. Also, make sure the "Set env." is checked (this will set the appropriate environment variables):
    Let me know if this helps.
    Reno.
