Host key verification failed - Submitting Fluent Jobs in LSF server
AlanAlan Member
edited November 16 in Ansys Products
Dear all,
I hope you are having a nice weekend!
I was trying to submit a Fluent job in a LSF server by using:
"fluent 3d -g -t4 -i ###.jou -scheduler_tight_coupling"
The job started successfully but stops very soon becaus of:
"Host key verification failed. Error: It seems ssh is trying to verify authenticity of c38b06. Please resolve it and try again! Client interrupted."
I checked online, some were using "export SSH_SPAWN=0" before the fluent submission command to avoid SSH verificaiton. But, I came across another problem:
"mpirun: rsh: Command not found"
Any inputs and suggestions are greatly appreciated!
thanks in advance!
Alan
    Sounds like permissions on the cluster: ie the host can't see/connect to the nodes.
  • AlanAlan Member
    Thank you Rob. I will contact the cluster adminstrator to resolve the problem then.
  • AlanAlan Member
    Dear Rob,
    I just contacted the admin team. They said that access to the compute nodes is handled by the LSF scheduler and direct ssh access to the compute nodes is not allowed. If my simulation requires ssh type of access, the 'blaunch' (https://www.ibm.com/support/knowledgecenter/SSWRJV_10.1.0/lsf_command_ref/blaunch.8.html) command should provide the same type of functionality.
    I was trying to use blaunch for fluent but can not find any guides from ANSYS Learning Forum. Do you by chance have any information about integrating blaunch with Fluent?
    thanks!
    Alan
    One for @mmadore then: I just break clusters....
    edited November 17
    @Alan For blaunch to work passwordless you need to set these variables:
    Please set the below two system environment variables
    In Bash Shell:
    export FLUENT_SSH=blaunch
    export SCHEDULER_RSH=1
    In C Shell:
    setenv FLUENT_SSH blaunch
    setenv SCHEDULER_RSH 1
    Also, you have to use -scheduler_tight_coupling in your command line.
    Matt
  • AlanAlan Member
    Thanks, Matt.
    I tried your commands (In Bash Shell). I used the following command to launch Fluent:
    It does use the blaunch as the system shows: "using remote shell blaunch". But, it still comes up with an error message:
    Error: It seems ssh is trying to verify authenticity of c39b12. Please resolve it and try again!
    Client interrupted.
    Any ideas to resolve this problem?
    thanks in advance!
    Alan
    Could you please try adding
    -mpi=openmpi
    Matt
  • AlanAlan Member
    -mpi=openmpi does not work. It says:
    A sequential map was requested, but not enough node entries
    were given to support the requested number of processes:
     Num procs: 4
     Num nodes: 1
    We cannot continue - please adjust either the number of processes
    or provide more node locations in the file.
    But, -mpi=intel works. But seems slower than default mpi (-mpi=ibmmpi) in the mpitest:
    for -mpi=intel with -scheduler_tight_coupling
    Ping pong latency test ...
    ping..pong..latency(usec)...count..host
    0.....1.....0.300575........10000..0:c40b06
    1.....2.....0.302362........10000..1:c40b06
    2.....3.....0.307225........10000..2:c40b06
    3.....0.....0.305513........10000..3:c40b06
    Ping pong bandwidth test ...
    ping..pong..bandwidth(MB)...count.msg-size(MB)..host
    0.....1.....8916.7..........10....4.............0:c40b06
    1.....2.....8597.53.........10....4.............1:c40b06
    2.....3.....8345.63.........10....4.............2:c40b06
    3.....0.....8744.05.........10....4.............3:c40b06
    Global reduction test ...
    MPI-function...time-per-msg(usec)..count...total-time(sec)..
    Bcast..........0.89159.............5000....0.00445795.......
    Reduce.........1.11198.............5000....0.00555992.......
    Barier.........0.34256.............5000....0.0017128........
    For -mpi=ibmmpi (which can not run Fluent because of the rsh problem)
    0.....1.....0.2452..........10000..0:c40b06
    1.....2.....0.2407..........10000..1:c40b06
    2.....3.....0.23835.........10000..2:c40b06
    3.....0.....0.248725........10000..3:c40b06
    0.....1.....7351.01.........10....4.............0:c40b06
    1.....2.....7340.88.........10....4.............1:c40b06
    2.....3.....7287.95.........10....4.............2:c40b06
    3.....0.....7446.61.........10....4.............3:c40b06
    Bcast..........0.49243.............5000....0.00246215.......
    Reduce.........0.57559.............5000....0.00287795.......
    Barier.........0.510406............5000....0.00255203.......
    Is the -mpi=intel a good option for running Fluent? or other -mpi options may be better?
