I had this solver pivot warning tried different ways but cannot resolve please help .
here you can find attached file ansys19.0. Also i have different beam profiles to model in single chassis is it possible to do so with the beam tool
Best Answers
  • peteroznewmanpeteroznewman Posts: 12,372Member
    Accepted Answer
    @soham Add a Modal analysis to your Model cell. Drag and drop the Fixed Support on the Modal analysis. You will find that the lines are not all connected.
    Go back to SpaceClaim and use Shared Topology to connect the beams together.
    Another way to do this is to Insert a Node Merge Group and merge the coincident nodes to connect the beam.
    Accepted Answer
    @soham
    1. Yes, each line can have its own profile using either method.
    2. There are many free courses under the Courses section at the top of this page.
  • sohamsoham Posts: 14Member
    @peteroznewman thank you so much sir . Have two more queries
    1. I have different tube cross sections which for time being I have modelled as single profiles so is it possible to apply different cross section to the tubing and still connect them ?
    2. What are the best resources to learn Ansys commands and their functionalities you'll refer sir ?
