Material frequency dependency maxwell 3d
Hello, I am simulating a transient with an Helmholtz coil which is inside mu-metal. Mu-metal is a material with high permeability which changes with frequency. I have made a simulation without the dependence between permeability and frequencies, now I would like to add this dependence. I can't find a way to do it. Any helps?
  • nchodenchode Forum Coordinator
    Can you upload some screenshots to understand what's your application is.
    As far as I know frequency dependent permeability data can be defined in HFSS. So, I just want to understand if your application has anything to do with simulating in HFSS.
    Regards
    Navya
  • Here you have the images, I have to simulate a transient. I sow you can change frequency and permeability dependence for a material in HFFS, but I think you can't simulate a magnetic transient. I am using "Maxwell 3D".
