Frequency-dependent permittivity
Hello
Is there any way to enter a permittivity that is a function of frequency in HFSS? And how?
Thanks.
  • rtkrtk Pune, IndiaForum Coordinator
    Hello @Hamad,
    Yes you can enter permittivity as a function of frequency in HFSS.
    In the edit material properties window, select Set frequency dependency and proceed as shown in the snapshot below:
    Just click on the Dataset blank cell to show the drop down menu. By this way either you can import a frequency dependent datasheet or can set frequency points as well.
    Hope this addressed your concern.
    Best Regards,
  • Hello rtk,
    Thank you so much. I appreciate your help.
