Rigid Body Motion error solution not converged.
Below is the model for which i want to do static analysis and want to evaluate the spring force. model is the simplified version of cylinder between two plate. i want to replace solid cylinder by nonlinear spring. i have force-deflection curve from which i am giving stiffness to COMBIN39 spring element. i am using ANSYS APDL for my simulation. i have fixed the bottom plate bottom surface in all direction. and compressive force is applied to top surface of upper plate. but i am getting the error of rigid body motion. Apart from this whenever combin39 element is arranged such that when compressive force is applied spring experience tension model (see another fig) is working fine and i got the spring force which is expected. Can anyone help me what is happening in the model below and why i am getting error of rigid body motion.
Purple : MPC184 link element
RED: Combin39 element
Rest is SOLID185 element. material properties is steel with 2.1E5 young's modulus and 0.3 poisson's ratio.
here is my code for model.
finish
/clear
/RGB,INDEX,100,100,100, 0
/RGB,INDEX, 80, 80, 80,13
/RGB,INDEX, 60, 60, 60,14
/RGB,INDEX, 0, 0, 0,15
/graphics,full
/pnum,mat
/prep7
R1 = 8 ! radius of cyl cyl. 1 (mm)
E1 = 2.08E5 ! modulus of cyl. 1 (N/mm^2)
nu1 = 0.3 ! Poisson's ratio of cyl. 1
E2 = 2.1E5 ! modulus of cyl. 2 (N/mm^2)
nu2 = 0.3 ! Poisson's ratio of cyl. 2
Load = 20000 ! load to be applied
Length = 24 ! length of cylinder in mm
!material properties
MP,ex,1,E1 ! E-modulus roller
mp,prxy,1,nu1 ! poisson's ratio
mp,ex,2,E2 ! E-modulus raceway
mp,prxy,2,nu2 ! poisson's ratio
et,1,solid185
et,2,mpc184
et,3,combin39
!!!!!!!!!!!!!!!!!!!!! upper plate generation
n,1,-1.25*R1,R1
n,34,1.25*R1,R1
fill,1,34,32,2,1
ngen,49,34,1,34,1,0,0,-0.5
ngen,6,1666,1,1666,1,0,2,0
mat,2
type,1
e,1,2,36,35,1667,1668,1702,1701
egen,33,1,1
egen,48,34,1,33,1
*get,highestE,elem,,num,max
egen,5,1666,1,highestE,1
allsel
!!!!!!!!!!!!!! bottom plate
*get,highestN,node,,num,max
n,highestN+1,-1.25*R1,-R1
n,highestN+34,1.25*R1,-R1
fill,highestN+1,highestN+34,32,highestN+2,1
ngen,49,34,highestN+1,highestN+34,1,0,0,-0.5
ngen,6,1666,highestN+1,highestN+1666,1,0,-2,0
mat,2
type,1
e,9997,9998,10032,10031,11663,11664,11698,11697
egen,33,1,highestE
egen,48,34,highestE-32,highestE,1
egen,5,1666,highestE-1583,highestE,1
allsel,all
!!!!!!!!!!!!!! Mpcs connection to master node !!!
!!!! 1 connection
n,100000,0,4,-4
n,100001,0,4,-12
n,100002,0,4,-20
n,200000,0,-4,-4
n,200001,0,-4,-12
n,200002,0,-4,-20
! 1st connection
nsel,s,loc,y,8
nsel,r,loc,z,0,-8
nsel,r,loc,x,-0.5,0.5
cm,node1MPCtop,node
nsel,s,loc,y,-8
nsel,r,loc,z,0,-8
cm,node1MPCbottom,node
cmsel,s,node1MPCtop
*get,nodempc1,node,,count
nodeonline=0
type,2
*do,i,1,nodempc1
nodeonline=ndnext(nodeonline)
e,nodeonline,100000
*enddo
cmsel,s,node1MPCbottom
nodeonline=0
type,2
*do,i,1,nodempc1
e,nodeonline,200000
*enddo
!!!!! 2 connection
nsel,s,loc,y,8
nsel,r,loc,z,-8.5,-16
cm,node2MPCtop,node
nsel,s,loc,y,-8
cm,node2MPCbottom,node
cmsel,s,node2MPCtop
*get,nodempc2,node,,count
nodeonline=0
type,2
*do,i,1,nodempc2
e,nodeonline,100001
*enddo
cmsel,s,node2MPCbottom
nodeonline=0
type,2
*do,i,1,nodempc2
e,nodeonline,200001
*enddo
!!! 3 connection
nsel,s,loc,y,8
nsel,r,loc,z,-16.5,-24
cm,node3MPCtop,node
nsel,s,loc,y,-8
cm,node3MPCbottom,node
cmsel,s,node3MPCtop
nodeonline=0
type,2
*do,i,1,nodempc2
e,nodeonline,100002
*enddo
cmsel,s,node3MPCbottom
nodeonline=0
type,2
*do,i,1,nodempc2
e,nodeonline,200002
*enddo
!  springs element
keyopt,3,1,0 ! unloading path same as loading
keyopt,3,2,0 !Compressive loading follows defined compressive curve (or reflected tensile curve if not defined)
!keyopt,3,3,2
keyopt,3,4,1 ! 3D springs
R,1,-0.076251,-75000/3,-0.052937,-50000/3,-0.035426,-32000/3
rmore,-0.023207,-20000/3,-0.012436,-10000/3,-0.00664,-5000/3
rmore,0,0,250,1000
real,1
type,3
e,100000,200000
*repeat,3,1,1
!!!! Boundary condition
nsel,s,loc,y,-18
cm,N_baseplate,node
cmsel,s,N_baseplate
d,all,all,0
allsel,all
nsel,s,loc,y,12
nsel,u,loc,x,-9.8,9.8
cm,N_sideedge,node
nsel,s,loc,y,12
nsel,r,loc,z,0
cm,N_frontedge,node
nsel,s,loc,y,12
nsel,r,loc,z,-24
cm,N_backedge,node
cmsel,s,N_sideedge
cmsel,a,N_frontedge
cmsel,a,N_backedge
cm,N_midedge,node
!d,all,ux,0
!d,all,uz,0
allsel,all
nsel,s,loc,y,18
nsel,r,loc,x,-4,4
cm,N_force,node
cmsel,s,N_force
*get,nodecount,node,,count
f,all,fy,-Load/nodecount
allsel,all
/solu
allsel
time,1
nsubst,2,20,1
nlgeom,on
autots,on
outres,all,last
solve
  • rkumbharrkumbhar PuneForum Coordinator
    hi @krada I didn't go through the whole script. But my guess is stiffness is very small compared to applied force on the spring. When the spring is compressed it pass through the bottom plate. My suggestion is to use joint and add stop option.
  • Thanks @rkumbhar for your answer. actually stiffness is calculated from the another model and validated with analytical solution. i think there seems to not be a problem but i did not get your point of using joint and stop option. i mean which type of joint and how it would be implemented?
