Define Monitor as a temperature matrix across the surface.
Hi
I am running fluent simulations for phase change process. I need to extract temperature as a matrix, each element of matrix corresponds to a temperature of a point on the surface. I found it very hard to define a separate monitor manually for each point. I am using Fluent 18.
Thanks in advance.
    You'll need to create several points and then monitor those. It's easier in 2020 as you can add multiple monitors to a single file and use the text editor to speed up creation.
    Alternatively, profiles can be used but you'll need to sift the data out of the files outside of Fluent.
