Can anyone help mw with meshing a simulation of a bird strike event using SPH method?
I am new to this Ansys software. I am recently doing a project of simulating a bird event. For this project I need to mesh the bird with hexahedral element (then converted to smooth particle), and the airfoil with shell elements of 0.5mm with seven integration points, with average element size of 10mm.
I just need to the procedure for doing this meshing.
Thanks in advance.
  • cxquancxquan Berkeley, CAForum Coordinator
    If you set the Reference Frame of the Bird to Particle and its Meshing method to Discrete Element, program will create SPH particles automatically, no matter what element type is used for the Bird.
