how to resolve unknown error which is non-recoverable by ANSYS ?
anamiyaanamiya Member
edited November 22 in Structures
In my modelling I'm unable to get any solution
 The above error is non-recoverable by ANSYS
 ANSYS run terminated by the indicated error
 Current data base saved if possible.
Is there any way to resolve my problem...Thanks in advance
*** FATAL ***                          CP =      0.672  TIME= 1***
 The requested number of distributed-memory processes (6) exceeds the
 number of physical processors that are available (4) on machine:
 LAPTOP-LTCEBCQU. The use of virtual processors is not recommended.
 It is required that you use a maximum of 4 distributed-memory
 processes on this machine.
  • *** FATAL ***                          CP =      0.672  TIME= 16:58:22
    does this have anything to do with the memory how can it be solved???
  • Thank you very much problem solved
