The optimization solution run was terminated. Check the Solver Output on the Solution Information
in 3D Design
Hi, i've been getting this message " The optimization solution run was terminated. Check the Solver Output on the Solution Information object for possible causes " everytime i tried to do topology optimization on my swing arm. I've attached all the values in the engineering data but still error. What should I do to fix this issue?
Hi @mohdizzatz ,
Please see if the following post helps:
Ashish Khemka
