unable to combine the surfaces for impact analysis
i used this link for reference https://youtu.be/EDtUeS9C_ik. Was unable to prepare the geometry please help its urgent
file is attached
Best Answers
peteroznewman Member
@soham Attached is a Parasolid V21 file. The trim is not perfect, but you get the idea.
- I added a solid sphere at the intersection of the tubes and made the diameter larger (1.25") than the tubes (1.0").
- I used the sphere with the Split Body tool to trim the tubes back to a common surface. Then I added a plane to slice a face into the four spheres. Then I selected the face of the sphere and used Copy/Paste to create a surface. Then I deleted the solid bodies. Then I used Combine to unite all the surfaces.
- In my initial reply I suggested you could "use Bonded Contact to connect edges of one part to the face of another part if the geometry won't merge." That would keep the tubes as close as possible to the original shape.
- Complex intersections like four or five tubes intersecting sometimes creates trimming operations that fail. That is why suggestion #3 is sometimes needed.
@soham
You should always say what version of ANSYS you are using.
If I edit your file in a newer version than you are using, you will not be able to open the file I worked on.
I'm not sure what you wanted at the front. It is okay to use Bonded Contact to connect edges of one part to the face of another part if the geometry won't merge.
Another approach is to introduce a clean body to trim each incoming tube to, then that becomes the connecting feature such as is shown below.
ANSYS SpaceClaim 2020 R1 document
sorry @peteroznewman i'm using workbench 19.0 ,yeah and as you said unable to open file. Thank you for the guidance. how can i clean bodies to trim them ?
it will probably solve my problem to do an explicit analysis. But i have few questions for you sir
represent my actual geometry
4.What possibly went wrong with original model? any tips will save my time in future .
Truly, thank You for your responses and guidance
@soham
@peteroznewman thank you so much sir !
