Disable constraints in a load step.
in Structures
Hi. I have a model consisting of several parts held together by bolts. Firctional contact is applied between the bodies. The bolts will be pre tensionsed in 3 stages. Due to this configuration the model is not very stable and I have issues getting it to converge.
What i would like to do is to add a zero displacement to some of the parts i the first 2 load steps, so that the bolt pre tensioning steps will converge. Thereafter I would like to disable the displacement before i apply the external loads. Is this possible?
Your help i appreciated.
@Ladderdale
Yes, in the image below, right click on row 2 to Deactivate the Displacement BC in step 2.
Ah, so its been hiding underneath there all the time:). I'll give that ago. Thanks for your help!
@peteroznewman
Worked great, thanks for your tip
