Moisture transfer across membrane
Abbasraza20000220Abbasraza20000220 Member Posts: 59
Hi all of you.
I am modelling membrane based heat exchanger. I need to make a udf for moisture transfer from one fluid to another in between membrane is inserted.
One fluid is moist air ( Air + water vapor) and other is dessiccant solution (Licl solution). while membrane is PVDF. I have defined moist air but now stuck in moisture transfer.
I am facing error in defining udf. Can annyone help me out?
Regards
Abbas Raza
