Using Help with links
Occasionally people will send links to the Help system rather than give a reference. These trigger a password check on the Ansys system, but.....
For anyone who is having the same problem as I have, i.e., not being able to access the URL (shows Customer Portal Login). You can access these links by:
- First open the help section of Ansys through the software ( ? button on the upper-right side of the Fluent Solver User Interface: This opens help in a browser)
- Copy the link you want to access
- Past it in browser URL (new tab) where the help documentation had been opened.
You can access these links. Just in case this helps someone.
Thanks to @smalbro93 for the hint.
Thanks Rob!
Hi @Rob , thank you.
