Format changing
Hello everyone, how can I transform .cdb or .db APDL format to .stl format in 19R1 version? Thank you for your help.
rkumbhar PuneForum Coordinator
You can use 'External Model' in Workbench to import .cdb file. Then Connect the External Model to Static Structural Analyis. From Static Structural analysis you can export Geometry in pmdb file. Or solve for dummy load and export deformation in stl format. The pmdb file can be read in Spaceclaim and convert into STL.
