Stiffness bevaiour to rigid as default instead of flexible when updating a model.
muhammadmuhammad Member
edited December 2020 in Preprocessing
Hello everyone,
I would like to ask, if there is any possibility to fix the behaviour of the body as rigid instead of flexible. Actually i am doing a parametric study using spaceclaim scripting. Scriting in spaceclaim always change the model when run several time for different design points. At each design point scripting updates the model in mechanical because of which model material properties set to default again which is flexible. So after 1st simulation it does not solve further.
Please let me know if anybody has any answer to tackle this or how can we change the default setting in ansys macros or if there is any apdl command for mechanical that could work.
Thanks in advance.
