Mechanical APDL Launcher not working
I recently installed Ansys Student Version and when i try to run the APDL launcher and click on the run button, the command window pops up and shows me the error as Check Firewall, even though all my firewalls are down. Please Help me.
You are most likely connected to VPN.
Do the following:
STOP your local License Manager
Edit the ansyslmd.lic file under the C:\Program Files\ANSYS Inc\Shared Files\Licensing\license_files directory and change the hostname to the loopback (127.0.0.7 ):
from
SERVER DESKTOP-H5PIUV5 FLEXID 1055
TO
SERVER 127.0.0.1 FLEXID 1055
Save the license file. Restart the ANSYS LM
Edit the ansyslmd.ini file and set the same information there and add the following variables (It should look like the following):
[email protected]
[email protected]
ANSYSLI_TIMEOUT_FLEXLM=15
ANSYSLI_FLEXLM_TIMEOUT_ENV=15000000
Test the application again.
Please let us know if this helps.
CORRECTION ON THE LOOPBACK INFO
Edit the ansyslmd.lic file under the C:\Program Files\ANSYS Inc\Shared Files\Licensing\license_files directory and change the hostname to the loopback (127.0.0.1 ):
I have the same problem, but instructions didn't help.
1) I cannot find that ansyslmd.lic file
2) I am not sure I have License manager in student version. Probably just cannot find it
Guess, I found the license manager.
Maybe this explains a bit my first problem.
