MatlabOptimizersForDX always fails
Dear Ansys Forum,
I am currently trying to start a test program using MatlabOptimizersForDX (https://catalog.ansys.com/product/5cc06907393ff65fd87cf921/matlab-optimizers). Using MOGA from Ansys when running DesignXplorer I have no problems and I converge to a solution. But using MatlabOptimizersForDX It won't even start the optimization. I simply get this error.
Update failed for the Optimization component in Direct Optimization. An error occured while updating the 'Optimization'. As I am new to ACT I do not understand what this error means nor does it provide me with enough information to solve the error. But I really need the matlab optimization to perform benchmark tests.
For my setup:
In workbench I have set up my optimization as you can see below in the figure.
I downloaded MatlabOptimizersForDX and put it in my documents folder.
I followed the Readme instructions in the pdf and installed the extension. I loaded the extension and I get to choose from all the different optimizers Matlab has to offer. I have tried using both standard values and custom vaues in the optimization, but it always fails when I update my solution. I am clueless and would appreciate any input.
Thanks!
Kremella Posts: 2,476Admin
ACTs don't generally have the same update cycle as Ansys products. At this point, we don't have this ACT compatible for our 2020 products. It will be updated at a later stage. In the meantime, if your work relies on the ACT, I'd strongly recommend that you use the R19.
So, I didn't fix the problem but I know what it is.
I use Ansys 20 but MatlabOptimizersForDX is only for 19.2. I luckily had 19.2, so I tried it with that and it works. This is not ideal for me. An update is needed for MatlabOptimizersForDX.
Hello Karthik,
Yes, I will work with 19. Thank you for the info!
Best
