TKE Production Suppression
heisenmechheisenmech Member Posts: 33
Dear all,
I've gone through online sources and UDF manual but haven't found any hint on suppression/disabling TKE production/dissipation in two equation based models?
I want to define a new production term, not just a source on the existing one.
Do you think TKE production may be suppressed by subtracting the term Fluent calculates for production ( mu_t * S^2) within new source?
or is there any more elegant way or even direct disable option?
Many thanks.
    Why do you want to suppress the turbulent production/dissipation? It sounds like you're trying to write a new turbulence model?
  • heisenmechheisenmech Member Posts: 33
    Not really. I 'm trying to re-define tke production by including non-linear stress-strain relation (as an explicit extension on Boussinesq constitutive relation).
    This source term will include Menter's GEKO model's approach for non-linear term together with linear term. Then, I want to test other readily available approaches. To do so, I, somehow, need to suppress default k-w SST tke production.
    Possibly not. You may need to recalculate the Fluent value in the UDF to remove it and then add in your terms.
    Thanks, Rob. That's what I thought as an alternative.
    Hi Rob,
    I've already created a topic but wanted ask you here too as it's a follow-up question.
    I want to compare contours of default tke production and user defined one with custom field (same way as Fluent calculates; mu_t*S*S). When I plot default tke production (production of k in turbulence tab), I get zero for the term everywhere in the fluid domain, whereas custom field function yields non-zero regions which is correct in physical standpoint. I also checked some of my other simulations. Production of k is zero in all cases.
    Any idea why?
