UDF Error - Ulibudf.dll : fatal error LNK1120: 1 unresolved externals
heisenmechheisenmech Member Posts: 33
Hi all,
I've checked almost all sources on how to get rid of the udf error below. All of the suggested methods are for typical udf compilation remedies, environment variables etc.
I've other udfs that are very similar to the current one, and are compiled smoothly.
I cannot share the code due to potential confidentiality issues, unfortunately.
I'd like to know if anyone had the same error with udf compilation, and found a way out.
Many thanks.
Error:
Creating library libudf.lib and object libudf.exp
udf1st.obj : error LNK2019: unresolved external symbol max referenced in function source_k
