Ansys Space claim blending error
Hi everyone,
when I try to do a custom curvature over the base of my geometry in Space Claim through the blend tool, the software is unable to blend/connect two of the faces. It brings up an errors saying:
As shown in this picture, I can blend all of the faces I want together except for these ones on the front of my geometry. This is the case for either the right side of the front and/or the left.
Sometimes this happens (when I add an extra point on the side) where the surface starts to curve around.
Thank you and let me know if you have any tips or need more details.
For blend tool, it is good have more guide curves.
Can you please make sure you have more guide curves.
I assume you are selecting faces in blend tool to create a solid. Please check if you can select edges and create surfaces. Then you can stitch faces together to create a solid.
Instead of creating a single large face, please check if you can create it in 2-3 patches.
Also please check if you can use combination of other commands like revolve using pull and then split it by plane etc.
Keyur
