What is the meaning of via system coupling in wall boundary condition?
zaynhaikalzaynhaikal Member Posts: 4
Hey guys. need help here because i have been confused a lot in system coupling in ANSYS Fluent. i was going to couple my fluid model in fluent into steady state thermal. so i set the wall boundary condition for thermal to via system coupling.
Then, there is an input there which is the heat generation rate. so i was confused, does the heat generation rate is coming from the fluid or coming from the outer region??
Really need your help!!
  • RobRob UKPosts: 8,855Forum Coordinator
    Accepted Answer
    Heat generation is if you want to add (or remove) heat into the model through a coupled wall. A common reason for using it would be a thin heating jacket in a wall to prevent a pipe from freezing: it's thin enough we don't want to use a solid zone but we do want to include the thermal source.
