Ansys 2019 R3 - spaceclaim license problem.
I am running Ansys 2019 R3 and recently updated the license file as per the recommended procedure.
However, when I try to use SpaceClaim or DesignModeler, I get the error report:
ANSYS LICENSE MANAGER ERROR
Capability ANSYS SpaceClaim Direct Modeller does not exist in the ANSYS licensing pool.
No specified user license preferences match available products in the specified licence path:
ANSYSLI_SEREVRS:
FLEXlm Servers: <path to the file student.lic.>
The student.lic file contains the following:
# The following key is for 'ANSYS Academic Teaching Introductory'
INCREMENT aa_t_i ansyslmd 9999.9999 31-jul-2021 uncounted \
F124AA2C2A65 VENDOR_STRING=customer:01055371 HOSTID=DEMO \
SUPERSEDE ISSUED=22-mar-2020 START=22-mar-2020 TS_OK \
SIGN2="0093 E043 EBD0 A365 54CD 9CA3 9E55 B000 36E2 7EAE 4529 \
7410 E398 9503 A1D5"
# The following key is for 'ANSYS AIM Student'
INCREMENT aa_s_aim ansyslmd 9999.9999 31-jul-2021 uncounted \
F9EA899D3D8F VENDOR_STRING=customer:01055371 HOSTID=DEMO \
SIGN2="0052 200F 34D0 F031 31BB 57B5 A37F 5200 A6E8 15AB 6D71 \
F1BA 1C66 D56D 3B3B"
# The following key is for 'ANSYS Discovery Live Student Version'
INCREMENT aa_s_disc ansyslmd 9999.9999 31-jul-2021 uncounted \
17C86E33B737 VENDOR_STRING=customer:01055371 HOSTID=DEMO \
SIGN2="00E0 8ED8 5B89 D5AD 24D7 547D E49B 5C00 217C A506 6345 \
9004 69DC 7636 278E"
INCREMENT aa_mcad ansyslmd 9999.9999 31-jul-2021 uncounted \
454421699B9F VENDOR_STRING=customer:01055371 HOSTID=DEMO \
SIGN2="00E0 3D9F A327 BE51 E646 DE8D 6030 F600 8A31 93FA BD3E \
D823 7F5B 3D3B 59F7"
Having searched the forum for possible solutions, I tried the
fix but no success. Running the diagnostic
"%awp_root201%\..\Shared Files\Licensing\winx64\ansysli_util" -checkout SPACECLAIM
produced
Messages file C:\Program Files\ANSYS Inc\ANSYS Student\Shared Files\Licensing\language\en-us\ansysli_msgs.xml does not exist.
2020/12/14 11:39:45 INFO Demo license file C:\Program Files\ANSYS Inc\ANSYS Student\Shared Files\Licensing\student.lic exists.
ANSYS LICENSE MANAGER ERROR : Capability ANSYS SpaceClaim Direct Modeler does not exist in the ANSYS licensing pool.
No specified user or site license preferences match products that enable this capability in the specified license path:
ANSYSLI_SERVERS:
FLEXlm Servers: C:\Program Files\ANSYS Inc\ANSYS Student\Shared Files\Licensing\student.lic
SPACECLAIM CHECKOUT FAILED
Any help and/or advice would be gratefully received!
Thanks.
drumlins Member
@mmadore Just an update to let you know I managed to get SpaceClaim to work. I did so by carrying out an uninstall of 2019 R3, then manually deleted all Ansys & spaceclaim folders left over. This was followed by a fresh install of 2019 R3 but before I started it for the first time, I firstly updated the student.lic file. Then I did the spaceclaim checkout test from within the command window and this time it seemed to work. Finally, opening Workbench, I was then able to access SpaceClaim.
Hope the above is of some use to others who find themselves in a similar situation. Thanks for all the earlier advice & suggestions!
@drumlins Can you please check to see if you have the ANSYSLI_ELASTIC environment variable set? If so, please delete it.
Please follow these steps.
Matt
Hello Matt,
Thanks for the advice. I've checked but there was no environmental variable by the name of ANSYSLI_ELASTIC.
William
@drumlins Please open a Windows command prompt and enter the command "set" without the quotes and send the full output.
Matt
Here you go (I've redacted some Windows entries for personal security reasons):
ALLUSERSPROFILE=C:\ProgramData
ANSYS195_DIR=C:\Program Files\ANSYS Inc\ANSYS Student\v195\ANSYS
ANSYS_SYSDIR=winx64
ANS_OLD_ATTACH=1
APPDATA=C:\Users\<withheld>\AppData\Roaming
asl.log=Destination=file
AWP_LOCALE195=en-us
AWP_ROOT195=C:\Program Files\ANSYS Inc\ANSYS Student\v195
CADOE_LIBDIR195=C:\Program Files\ANSYS Inc\ANSYS Student\v195\CommonFiles\Language\en-us
CommonProgramFiles=C:\Program Files\Common Files
CommonProgramFiles(x86)=C:\Program Files (x86)\Common Files
CommonProgramW6432=C:\Program Files\Common Files
COMPUTERNAME=<not disclosed>
ComSpec=C:\WINDOWS\system32\cmd.exe
DriverData=C:\Windows\System32\Drivers\DriverData
FPS_BROWSER_APP_PROFILE_STRING=Internet Explorer
FPS_BROWSER_USER_PROFILE_STRING=Default
HOMEDRIVE=C:
HOMEPATH=\Users\<withheld>
LOCALAPPDATA=C:\Users\<withheld>\AppData\Local
LOGONSERVER=\\<not disclosed>
LSTC_LICENSE=ANSYS
NUMBER_OF_PROCESSORS=8
OneDrive=C:\Users\<withheld>\OneDrive
OS=Windows_NT
Path=C:\SIMULIA\Commands;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\Program Files (x86)\Common Files\Oracle\Java\javapath;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\WINDOWS\System32\OpenSSH\;C:\Program Files (x86)\Calibre2\;C:\Program Files (x86)\Common Files\Acronis\VirtualFile\;C:\Program Files (x86)\Common Files\Acronis\VirtualFile64\;C:\Program Files (x86)\Common Files\Acronis\FileProtector\;C:\Program Files (x86)\Common Files\Acronis\FileProtector64\;C:\Program Files (x86)\Common Files\Acronis\SnapAPI\;C:\Program Files\MATLAB\R2020b\bin;C:\Program Files\MATLAB\R2019b\bin;C:\Program Files (x86)\Windows Kits\8.1\Windows Performance Toolkit\;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\WINDOWS\System32\OpenSSH\;C:\Program Files\Git\cmd;C:\Program Files\dotnet\;C:\Program Files\Microsoft SQL Server\130\Tools\Binn\;C:\Program Files\Microsoft SQL Server\Client SDK\ODBC\170\Tools\Binn\;C:\anaconda3;C:\anaconda3\Library\mingw-w64\bin;C:\anaconda3\Library\usr\bin;C:\anaconda3\Library\bin;C:\anaconda3\Scripts;C:\Users\<withheld>\AppData\Local\Programs\Python\Python38-32\Scripts\;C:\Users\<withheld>\AppData\Local\Programs\Python\Python38-32\;C:\Users\<withheld>\AppData\Local\Microsoft\WindowsApps;C:\Users\<withheld>\AppData\Local\atom\bin;C:\Program Files\JetBrains\PyCharm Community Edition 2020.2\bin;C:\Users\<withheld>\AppData\Local\GitHubDesktop\bin;C:\Users\<withheld>\AppData\Local\Microsoft\WindowsApps;D:\apps\FFmpeg\bin;C:\Users\<withheld>\.dotnet\tools
PROCESSOR_ARCHITECTURE=AMD64
PROCESSOR_IDENTIFIER=Intel64 Family 6 Model 94 Stepping 3, GenuineIntel
PROCESSOR_LEVEL=6
PROCESSOR_REVISION=5e03
ProgramData=C:\ProgramData
PROMPT=$P$G
PSModulePath=C:\Program Files\WindowsPowerShell\Modules;C:\WINDOWS\system32\WindowsPowerShell\v1.0\Modules
PUBLIC=C:\Users\Public
PyCharm Community Edition=C:\Program Files\JetBrains\PyCharm Community Edition 2020.2\bin;
SESSIONNAME=Console
SystemDrive=C:
SystemRoot=C:\WINDOWS
TEMP=C:\Users\<withheld>~1\AppData\Local\Temp
TMP=C:\Users\<withheld>~1\AppData\Local\Temp
UGII_3DCONNEXION_DIR=C:\Program Files\3Dconnexion\3DxWare\3DxNX64\ugii_dir\
UGII_3DCONNEXION_DIR32=C:\Program Files\3Dconnexion\3DxWare\3DxNX64\ugii_dir32\
USERDOMAIN=<not disclosed>
USERDOMAIN_ROAMINGPROFILE=<not disclosed>
USERNAME=<withheld>
USERPROFILE=C:\Users\<withheld>
windir=C:\WINDOWS
@drumlins Please try renaming each of these three directories by adding .OLD at the end.
%APPDATA%\Ansys\v195
%APPDATA%\SpaceClaim
%LOCALAPPDATA%\SpaceClaim
OK, that's done now and I've tried again with SpaceClaim but I'm still getting the same error message.
Hey @drumlins I'm also facing the same issue. You told that you updated the student.lic file right. Can u tell what exactly you mean by updating it and how to do it step by step?
Eagerly waiting for your answer
Natesh
The post "How to Renew Ansys Student Product License" has all the steps you need to take.
