Autodyn subroutine: Grid variable and IJK solvers
I used mdeos_user_1.f90
(equation of state user subroutine) for air (a single material), and during debugging, I wanted to see if the internal energy and temperature changes were correct.Refer to the ANSYS-Autodyn-Users-Subroutines-Tutorial.pdf. For grid variables, use the function" GV3 "
- But I didn't get the right answer by using the function
" GV3 "
, the internal energy was always 10, and the temperature was always 0. As shown in the picture below,the variable name isINT_ENERGY
andTEMP
- I try the method of obtaining Multi-material variable.The correct temperature and internal energy results are obtained by using the subroutine
"GETMLT3"
.the variable name isint_energy1
andtemp1
Have you ever come across this situation ? Why the function "GV "
didn't get the right value while the subroutine "GETMLT3"
can get the right value?
GV3 is used for grid variables such as the variables in Lagrange solver. For multi-material Euler solver, GETMLT/PUTMLT should be used to get the multi-material variables and store them properly after.
@cxquan
Thank you for your answer!
I did choose Lagrange solver ,but GV3 can't get the right temperature and internal energy when I was debugging😫
