Installing Ansys 2019R1 on Cray/CLE environment.
We have configured the arc master on login node and arcnode on compute node. When we test the RSM it gives error as, cannot submit job and failed to start the arcnode.
Thank you
  • RSM Version: 19.3.328.0, Build Date: 11/18/2018 14:06:25
    Job Name: RSM Queue Test Job
      Type: SERVERTEST
      Client Directory: /hpchome/hpcadmin/.local/share/Temp/RsmConfigTest/2r2bm361.x9s
      Client Machine: login
      Queue: RSM Queue [localhost, default]
      Template: SERVERTEST
    Cluster Configuration: localhost [localhost]
      Cluster Type: ARC
      Custom Keyword: blank
      Transfer Option: None
      Staging Directory: blank
      Local Scratch Directory: /workarea/workarea/ansys
      Platform: Linux
      Using SSH for inter-node communication on cluster
      Cluster Submit Options: blank
      Normal Inputs: [*,commands.xml,*.in]
      Cancel Inputs: [-]
      Excluded Inputs: [-]
      Normal Outputs: [*]
      Failure Outputs: [-]
      Cancel Outputs: [-]
      Excluded Outputs: [-]
      Inquire Files:
       normal: [*]
       inquire: [*.out]
    Submission in progress...
    Runtime Settings:
      Job Owner: hpcadmin
      Submit Time: Thursday, 17 December 2020 15:26
    2.67 KB, .05 sec (55.81 KB/sec)
    JobType is: SERVERTEST
    Final command platform: Linux
    RSM_PYTHON_HOME=/workarea/athenasoftwares/ansys2019R1/ansys_inc/v193/commonfiles/CPython/2_7_15/linx64/Release/python
    RSM_HPC_JOBNAME=RSMTest
    Distributed mode requested: True
    RSM_HPC_DISTRIBUTED=TRUE
    Running 5 commands
    Job working directory: /hpchome/hpcadmin/.local/share/Temp/RsmConfigTest/2r2bm361.x9s
    Number of CPU requested: 1
    AWP_ROOT193=/workarea/athenasoftwares/ansys2019R1/ansys_inc/v193
    Testing writability of working directory...
    If you can read this, file was written successfully to working directory
    Writability test complete
    Checking queue default exists ...
    Job will run locally on each node in: /workarea/workarea/ansys/ack7tpu4.7hx
    JobId was parsed as: 1
    External operation: 'queryStatus' has failed. This may or may not become a fatal error
    Status parsing failed to parse the primary command output: '
    External operation: 'parseStatus' has failed. This may or may not become a fatal error
    Parser could not parse the job status. Checking for completed job exitcode...
    Status Failed
    Problem during Status. The parser was unable to parse the output and did not output the variable: RSM_HPC_OUTPUT_STATUS.
    Error: Please check that the master service is started and that there is no firewall blocking access on ports 11193, 12193, or 13193
    Output:
    The status command failed to get single job status to the master service on: login:11193.
    Status Failed
    Output:
  • RSM_PYTHON_HOME=/workarea/athenasoftwares/ansys2019R1/ansys_inc/v193/commonfiles/CPython/2_7_15/linx64/Release/python
    Running 5 commands
    Job working directory: /hpchome/hpcadmin/.local/share/Temp/RsmConfigTest/gdqlpi3q.1d8
    Checking queue local exists ...
    Submit parsing failed to parse the primary command output: 'ArcMaster process running as rsmadmin
    External operation: 'parseSubmit' has failed. This may or may not become a fatal error
    ARCNode Process could not be reached
    Skipping autostart because Master processes is started as a service.
    Job not submitted. Error: Job is too big to fit in the queue local with the currently assigned machines.
    Failed to submit job to cluster
    Submit Failed
    Problem during Submit. The parser was unable to parse the output and did not output the variable: RSM_HPC_OUTPUT_JOBID.
    Error:
    Output: ArcMaster process running as rsmadmin
  • Exec Node Name     Associated Master     State     Service User   Avail  Max  Avail  Max  Avail  Max
         nid00033         login       Running      root      72   50   *   *   *   *
         nid00034         login       Running      root      72   50   *   *   *   *
      * Indicates that resources have not been set up. Any resource request will be accepted.
    Updating Users and Groups...
    Groups matching *
     rsmadmins
    Users matching *
     root
     rsmadmin
    Updating queues...
         Name      Status   Priority  Start Time  End Time  Max Jobs   Allowed Machines     Allowed Users
        default      Active    0    00:00:00   23:59:59   *   login:nid00033:nid00034      all
        local      Active    0    00:00:00   23:59:59   *        login          all
  • MangeshANSYSMangeshANSYS Forum Coordinator
    Please refer RSM documentation, search for "Example: Setting Up a Multi-Node ANSYS RSM Cluster (ARC)". Please double check that all the lines in Step #1 were followed. The arcmaster node needs to be able to communicate with the arcnode
  • I have setup the ARC master and client nodes and they can communicate with each other. I can see the execution nodes and I have setup the queues using the arcconfigui.
    I have configured the RSM and I can see the queue of ARC in it. Once I submit the jobs from the RSM the arc master service is stopped ?? and the process gives as can't communicate to arc master
