FW and MTPA characteristic
in Electronics
Hello!!!!
I am working with a magnet assisted synchronous reluctance motor (PMa-SynRM) and I am trying to get the constant power characteristics. Without the assistance of the magnet I obtain the characteristic constant torque through the Machine Toolkit, but when I use the magnet the characteristic doesn't give me something reasonable. Does this kit not work for this type of machine?
Could you tell me if there is a tool to calculate the constant power characteristic or any suggestion to obtain it, any idea or suggestion is good....
Thanks!!!!!
Hi @Cesar
PMASRM is also a kind of IPM machine. Machine toolkit supports IPM machine.
So it should work for PMASRM as well I think.
Best regards,
Navya
Hi Navya
I tried to simulate it as an IPM but it gave me inconsistent results. I'll give it a try....
Thanks for your time....
Best regards,
Cesar
HI @nchode
I followed his advice and ran the simulation as a IPM machine, but the results I don't think are correct, I show you
without PM
with PM
Theoretically, the torque on the assisted machine must be higher, but it is not the case...the simulation was carried out under the same conditions.
Best regards,
Cesar
