Error in FSI. The couple update for the system static structural threw an exception.
Hi, I am trying to analyze 2-way FSI. In both static structural+steady fluent and transient structural+transient fluent, I have encountered same error:
"Update failed for the Solution component in system coupling. The coupled update for system Static Structural threw an exception. Error updating cell solution in System Static Structural."
Solution Information:
| Warnings were found during data model validation.              |
| Restart output is only requested at last step. To enable restarts from   |
|   intermediate points, use another 'OutputControl' option.        |
| Participant CouplingParticipant:Solution 1 has the ExecutionControl     |
|   'Option' set to 'ExternallyManaged'. System Coupling will not control  |
|   the startup/shutdown behavior of this participant.           |
| Participant CouplingParticipant:Solution has the ExecutionControl 'Option' |
|   set to 'ExternallyManaged'. System Coupling will not control the    |
Awaiting connections from coupling participants...
| "System coupling solution stopped before all participants connected. A   |
| solver failure occurred during the run in the Static Structural system"
