opening Ansys HFSS files in previous versions of Ansys HFSS
My university has Ansys HFSS 18.0 installed on its HPC servers. But workstation in our labs have Ansys HFSS18.2. whenever I upload a model designed on my workstation to the HPC and try to run it it shows
[warning] This project was last saved with version 2017.2. You are attempting to open this file in a lower version than the one in which it was last saved. Unexpected results may occur if you proceed.
[Exiting application]
is there any possible way to run it.
@Mondeep It is not recommended to attempt running with older versions. There is no safe process to make it work. You will run the risk of lost data or corrupted files.
Matt
