How to determine the equation of a spline curve drawn using Design Modeller in ANSYS WB?
in 3D Design
Dear friends,
Greetings!!!
I have drawn an open spline curve in ANSYS WB Design Modeller using 3 control points. I would like to determine the equation of the curve generated with the given inputs. Can someone help to identify it or suggest the procedure to determine the equation of generated curve?
Thanks in advance
Hemnath
May I ask you why do you want that equation? You will not be able to change it in DM.
You may want to check help manual for that.
You can use equations in SpaceClaim.
Keyur
Sir,
I would like to know the equation in order to parameterize it for various points on the curve.
I have already created a open spline curve in DM using 3 points, but I would like to know the parametric equation for that curve. How to determine the equation? what's the background calculation involved? Could u please kindly help me out?
Thanks in advance
Hemnath
