Beam Connection - Stress
So, in bolted connections one can use a Body-Body beam. You can probe the connection in Solution in order to see reaction forces and moments.
But is it possible to obtain the stresses?
Hi @Cyberz ,
You can drag and drop the beam used for bolted connection under the Solution branch and then you can see the Force and Moment reactions in the Detail Window.
For stress calculation, you may use the force values:
Ashish Khemka
