How much a difference do LS-DYNA versions have? R7.0 and R11.0 particularly.
Hi all,
I once used LS-DYNA R7.0 to model an underground pipe full of water, and recently I have modeled the pipe again, using LS-DYNA R11.0. It shocked me that there is a noticeable difference in the results. I have narrowed down the reason to either CONSTRAINT_LAGRANGE_IN_SOLID or EOS_GRUNEISEN.
I would appreciate if someone can tell me why there is such a difference.
tslavik Member
The notes for all LS-DYNA releases can be found here. Use those notes as a guide to track down the responsible change. Between the releases you mentioned, there have been many fixes and changes to *CONSTRAINED_LAGRANGE_IN_SOLID, and only a few changes to the EOS.
https://ftp.lstc.com/anonymous/outgoing/support/FAQ/ReleaseNotes/
Also, you should run all of the releases between R7.0.0 and R11.0.0 to further narrow it down, e.g., R8.1.0, R9.1.0, R10.1.0, etc.. Those executables can be downloaded here:
http://ftp.lstc.com/user/ls-dyna (for SMP executables)
http://ftp.lstc.com/user/mpp-dyna (for MPP executables)
Also re-run with the latest release R12.0.0 since that should contain the most up-to-date changes.
I guess you are right. It seems that CONSTRAINED_LAGRANGE_IN_SOLID is a tricky keyword to use, and I should be more cautious using it.
Thanks for the help.
