Applying a heat source inside a fluid domain
I am essentially trying to make a simple model of a hot wire inside a fluid domain, I'm starting with very simple geometry (pic below). I'm only interested in the heating from the wire, so my first thought was to use a UDF to define an energy source in a region in the fluid zone. However, this doesn't seem to work. I am new to UDF's so most likely my code is wrong (attached below).
Is there a better way to go about the problem?
#include "udf.h" DEFINE_SOURCE(sourceterm,c,t,dS,eqn) { real x[ND_ND]; real source; C_CENTROID(x,c,t); if(x[0]>=5 && x[0]<=10 && x[1]>=0 && x[1]<=12) { source=50000; } else { source=0; } return source; }
What issue do you get when you compile this UDF? Can you share the error message here?
Also, why don't you use the Fluent Expressions directly here? Here is a link that might help you with the expression. Please go through this chapter in the Users Guide.
