Doubts about the Piston-resting Design.
in 3D Design
Hi friends,
I have been bit stuck with the CAD drawing issue, where the piston need to rest on the outer cylinder circle rim. I tried many ways in solid work as well as the space claim to make that resting position but failed to see all the time gap between them. I tried using the pull in space claim but even I cant make it touch to the piston, it get little bit interfere and if I pull less it didn't touch the surface part.
The surfaces are probably of different shapes. I would suggest you to pull the piston in SpaceClaim beyond the rim and then you can split and perform a boolean operation on the extended part.
