i saved one project "induction machine1" in Ansys Electronics desktop
but when i open it in workbench , it show error. if any one can understand my problem , please suggest me solution
  • Hi,
    Best way to work with workbench is to start from workbench. that means in workBench you can insert a Maxwell component and after opening the Maxwell component from WorkBench you can add more design within the Maxwell. now when you close the Maxwell it will update the workbench project as well.
    btw, why are you trying to import the Maxwell project into workbench?
  • i was already working on project which i saved ,so want to open it again
