How to open LS-DYNA?
I have a problem using ANSYS LS-DYNA. I have installed the ANSYS software through CMC with the license: Ansys Campus Solutions (Research). Later, since I needed to work with LS-DYNA, I found that the student version has this for free. I have installed the Ansys 2020R2 LS-DYNA Student. However, I cannot open LS-DYNA. Image1 shows the options I see through the start menu.
When I click on LS-DYNA PowerShell from the Start menu, the LS-DYNA Powershell window pops up. (Image2)
From this window, I can open LS-Prepost just by typing lspp. However, to work with LS-DYNA, when I type lsdyna in the command prompt, it gives the following error (Image3), and I am not sure how to fix it.
Your help is truly appreciated!
peteroznewman Member
The Start Menu for Ansys 2020R2 LS-DYNA Student has an item called LS-Run. That is what I used to run a .k file. Once it ran, I was able to open LS-PrePost to look at the results.
I didn't use the LS-DYNA Powershell at all.
@AfsoonNejati
@peteroznewman
Thank you so much for your reply. Yes! that worked. However, still, I don't have any access to the LS-DYNA Program Manager ...
Kind regards,
please help me use LS-Run i made a keyword file and I'm trying to run it in LS-Run in the student version. But when i see other video's on YouTube they are using full version so i cant find the location of solver file to use in student version .I have highlighted in yellow
