Running problem
I am using CFX and I have a problem with the CFX -solving step,.
When I am trying to make a run, sometimes it is working and much more time is not working.
Like the attached photos, it is two trials for making a run for the same file. once it gave me a license problem, however, I am using a version with a license.
second, it gave another error with code 1.
I am confusing and I do not know what is the problem.
Thanks in advance
mmadore Forum Coordinator
@Aya The problem is that there are not enough licenses. All licenses are in use when you encounter this issue. The error message is telling you there are not enough licenses.
Regarding the other error mentioning "Isolated Fluid Regions", I would recommend logging that as a separate post under the Fluids section: https://forum.ansys.com/categories/fluids
Thank you,
Matt
Thank you,
Matt
@mmadore Thanks a lot for your kind reply.
