reg_ansysedt_error
I have installed Ansys 18.0. But unable to open. I saw this forum for the solution, tried running configThisMachine got an error. How to get resolve this issue?
@Ranjitha This issue is due to a Windows Update, Microsoft update KB4571756. The solution for version 18.0 is to uninstall the Update.
To uninstall the Windows update:
1. Select the start button or Windows Desktop Search and type update history and select View your Update history.
2. On the Settings/View update history dialog window, Select Uninstall Updates.
3. On the Installed Updates dialog window, find and select KB4571756, and then click the Uninstall button.
4. Restart your Windows device.
Additionally, you may be able to run the following from an elevated CMD to uninstall the update:
wusa /uninstall /KB:4571756 /quiet /promptrestart
For versions 2018.0 (19.0) and newer, you may try setting the environment variable ANSYS_EM_DONOT_PRELOAD_3DDRIVER_DLL=1 to get around the problem.
For guidance on creating an Environment Variable please refer to this link. You need to create a NEW Variable.
https://www.onmsft.com/how-to/how-to-set-an-environment-variable-in-windows-10
New Variable Name: ANSYS_EM_DONOT_PRELOAD_3DDRIVER_DLL
New Variable Value: 1
Thank you,
Matt
I tried everything. But it's not happening. I followed each step and did.
@Ranjitha Can you please provide a list of all current Windows Updates installed?
@Ranjitha What happens when you try to open Electronics Desktop? Do you see any error messages or does it just not do anything? Have you tried installing a newer version?
Matt
When I try to open it. It will just load but does not open. No error. Can you send a newer version link? I mean for Electronics Desktop.
Thank you. I downloaded Ansys 19 version. It worked.
That's great, happy to hear it!
