Rolling sheet - contact
chrumdzikchrumdzik Member
edited January 4 in 3D Design
Dears,
I wonder why the steel plate crossing the rollers during simulation of rolling sheet plate?
Thanks in advace for tips.
Jerzy
    edited January 4
    @chrumdzik
    In the details window, you changed the Normal Stiffness Factor to 0.01 which is used to multiply the stiffness ANSYS calculated to keep the two parts from penetrating. Change that back to 1 and you will get 100 times less penetration. If that is still too much, you can use a Normal Stiffness Factor of 10 or more to get even less penetration.
