Ansys Student can do a two way FSI coupled system?
I do a two way FSI simulation like the oscillation plate tutorial but after some coupled iterations show some errors...But I don't think they caused by License.
CFX output as follow:
COEFFICIENT LOOP ITERATION =39000 CPU SECONDS = 1.835E+04
| Equation | Rate | RMS Res | Max Res | Linear Solution |
| U-Mom-Bulk | 0.95 | 9.2E-03 | 6.9E-01 | 7.1E-04 OK|
| V-Mom-Bulk | 0.00 | 0.0E+00 | 0.0E+00 | 0.0E+00 OK|
| W-Mom-Bulk | 1.16 | 7.1E-02 | 4.7E+00 | 7.0E-04 OK|
| P-Vol | 0.97 | 1.3E-04 | 3.7E-03 | 9.9 2.9E-03 OK|
| Mass-Water | 1.00 | 2.2E-03 | 6.3E-02 | 10.6 3.4E-08 OK|
Convergence Warnings Summary
| Equation Class | Solve Location | Number of |
| | | Convergence |
| | | Failures |
| Momentum and Mass | DEFAULT | 1 |
| Volume Fractions | DEFAULT | 1 |
| ERROR #001100279 has occurred in subroutine ErrAction. |
| Message: |
| A System Coupling error occurred while the request "AssignToken" |
| was being served. |
| Writing crash recovery file |
| Message: |
| Stopped in routine CP_ServeUntil |
| An error has occurred in cfx5solve: |
| The ANSYS CFX solver exited with return code 1. No results file |
| has been created. |
End of solution stage.
| The following transient and backup files written by the ANSYS CFX |
| solver have been saved in the directory |
| E:/Thesis/Elastic-Wall/Elastic |
| Wall_pending/dp0_CFX_Solution_1/Fluid Flow CFX_002: |
| 0_full.trn |
| Warning! |
| The ANSYS CFX Solver has written a crash recovery file. This file |
| has been saved as E:/Thesis/Elastic-Wall/Elastic |
| Wall_pending/dp0_CFX_Solution_1/Fluid Flow CFX_002.res.err and may |
| be an aid to diagnosing the problem or restarting the run. More |
| details should be available in the solver output section of the |
| output file. |
| The following user files have been saved in the directory |
| trace |
| For CFX runs launched from Workbench, the final locations of |
| directories and files generated may differ from those shown. |
This run of the ANSYS CFX Solver has finished.
