export result analysis from Discovery
What is the best way to export analysis plot after the simulation has finished? I mean a simple picture showing contour plot and values, for different design points.
thank you so much for your help!
Hello sentenza
I assume your question is related to Discovery Live. There is no option to automatically export the contour plots for each Design Points. You will have to manually take snapshots for each contour plots.
For result values, there is an option to save the calculated results of all design points to a csv file. This Save option is available on the Parametric study table.
thank you very much for the information
