I'm constantly encountering an error while meshing. Whenever I try meshing the error "update failed for the component. error updating cell mesh in system fluid fluent" . In order to fix this error I tried renaming the file but still I'm getting the same error. I tried meshing in other analysis as well like static structural but still theres this same error with meshing.
@System what is your new question here? Please post here. If it is installation related please select Ansys Products as category.
@nehayelve12 As ANSYS Staff, we can not download attachments. Please upload images using upload image functionality. Also if it is not related to question from @System , then please create a new discussion.
I've attached the screenshots of the errors .
Regards
It also helps if you log questions in the appropriate section rather than adding to an old (and unrelated) thread.
Keyur
