Double integration in HFSS
The bistatic RCS is already available in HFSS. What I want to obtain is the total RCS, which is defined as shown in the attached picture.
Could anyone help me with this, please?
  • pmunagapmunaga Forum Coordinator
    Hi @Hamad,
    Thank you for reaching to us.
    You can use "Field Calculator" to evaluate equations as per your need.
    Please go through "Using Field Calculator" section of "Post Processing and Generating Reports" chapter provided in the HFSS Help document to have a detailed understanding on the use of field calculator.
    All the very best.
    Best Regards,
  • HamadHamad Member
    Hi pmunaga,
    Thank you so much for your reply. I will look at it.
