How To Add Angle To The Bend Component In NEXXIM
in Electronics
I have been working on the simulation of wilkinson power divider. In order to give the required angle to my transmission lines, I need to assign bending angle to the bend component. However, it only gives two parameter which are width of transmission line.
Is there any way of achieving this without designing new component or can I assign parameter to an existing component?
Thank you...
Figure 1: The bend component that I used
Figure 2: Parameters of the bend component
Figure 3: Component values
Hello @EfeK,
This is the best way to do that and you can utilize the W1 and W2 accordingly to customize your conductor's widths at both ends.
Or, the other possibility is to model one microstrip bend or any type of bends in HFSS and extract their S-parameter to circuit. If you want a usual/common bend then go for the component itself.
Hope this addressed your concern.
Regrads,
