Please provide some more details about the issue. Here are some best practices for using the forum:
Be efficient – To get answers fast, always search for your question before creating a new post.
Be clear – Provide supporting screenshots, error messages, and background information in your post instead of attaching a simulation file.
Be precise – Post your questions in the right categories and use correct tags to help our engineers find your question.
Be patient – Please allow up to three days for someone to get back to you. If you have an urgent question, email your Ansys Account Manager.
Be helpful – Consider giving back to the engineering ecosystem by answering questions from others and telling your friends and colleagues about this resource.
When the solve is initiated, the checks done before the first cycle can find problems and produce warning or error messages. These are usually related to the material models, the boundary conditions setup, or the restart options. When a General failure error is seen, this usually means there are possible problems with the licensing or the remote solve manager, but it can also signify other problems. Errors or warnings can also be seen during or after the solve. The two primary reasons for a terminated solve are the Energy error exceeded and Time step too small errors. Both of them can mean a variety of problems - meshing, high deformation, incorrectly applied forces, etc. Usually observing the results up to that point or using the erosion or error options to bypass the termination should give an indication of what the problem might be.
-Aniket
Thank you, I will for sure
Using v16
Explicit analysis
Lower quality Mesh is not getting generated
Result is ending with this error in the image attachment
What can be the solution to the error "a general failure has occurred during solution" in ansys explicit dynamics
More info at:
-Aniket
Thank you very much, I will definitely check out the link
