Curve fitting for hyperelastic material model with uniaxial compression test data
Hello!
I'm trying to model a PVC cable sheath with hyperelastic material behaviour and therefore, among other things, I conducted a uniaxial compression test. I read/heard that test data from uniaxial compression and biaxial tension are interchangable with regard to using it for curve fitting in combination with the Mooney-Rivlin model f.e.
If I put in the data as uniaxial compression data the curve fitting won't acknowledge it at all (it seems, that processing uniaxial compression data is not supported for hyperelastic models - at least, that's what I took away from the ansyshelp page).
So my question is: Do I just take the data of the compression test and put it in as biaxial tension? If not, what's the right way to do it?
Cheers,
Sebastian
rkumbhar PuneForum Coordinator
Hi @sebrigify You can include both compression and tension in the "uniaxial test data" and put the values in ascending order. There should be also a (0,0) data point in the list.
Thank you @rkumbhar
I did as you said. After the curve fitting the biaxial curve is still all over the place (no wonder), but I reckon if I don't have that particular kind of load it'll be ok.
Cheers
